1 - 4 of 4 Posts
Hey,
I'm toying with the idea of using an old ABB industrial controller to run a small ac motor in a small car.
I've heard you can use DC as an input source into the ac power input to the drive, the drive then converts the ac to dc anyways, then reconverts it to the AC it likes to drive the ac motor.
I've got the drive, motor and spare batteries. I'll hook up the "boy" wires to the motor, then start adding batteries till I see the light.
Unless someone thinks thats a bad idea...
I work at Coca-Cola, who upgraded drives a few months ago, and gave me about 10 old drives!
Hello F16bmathis,
I posted the same question on pg 2or3 in controllers check out the answers it might help. The ABB VFD you have is it 480v? This is a common industrial plant voltage and mine was also, which adds some complications. Please pm me or post any info here if you keep going on this and get something to work. Ill keep checking.
A newbie/beginner
TX Chris Sandberg :)
Right in the manual, it says you can use 250 VDC. I'd like to try and get that a little lower, so I'll see if I can play with them some. I have 3 or 4 different models, so maybe I can get one of them to work on lower voltage.
The HP has got to be pretty low, but the manual says it can go higher than its rated value, but it was used at Coca-Cola to run an agitator motor, so maybe 3-4 hp?
So its just something to play with until they can invent a car that does 60 mph at 10 amps!
1 - 4 of 4 Posts
