Installed in a 1998 Subaru Forester with manual trans. Motor is drawing no ah and will not rev above 2000 rpm. RPM slowly increases, doesn't matter what gear transmission is in. Showing code 17 on Curtis 840 which I think is severe under voltage. In neutral motor revs easily pass 3500 rpm. Read article about limp mode. Using 8 batteries 12.4 volts and 700 ahs I assume we will have to rent a Curtis programmer to change any parameters (Battery menu). Help would be appreciated.
Dave And Joe
Hi, go write a forum post, this is wiki section...
Dave And Joe
