Hi to all.
I'm converting my Ford, from 1990, to EV.
The motor that am using is AC cage motor.
Technical info:
VEM motor - 11 or 13KW connection
1850 RPM
Car weight : 770 kg ( without batteries )
AC controler : Siemens 40KW ( 200- 450V DC input )
Battery bank: 15KW ( at least )
Transmission is kept and the motor is connected to this transmission.
5 gear transmission.
Car weight after battery installation - max 850 kg.
Battery's will be homemade.
Questions:
- before i design battery bank i need to find out how much current can this AC motor drawn on let's say highest consumption. First gear etc. ?
- can i set 300VDC at 50 Ah. Will this be enough current ?
- based on this design, what do you think, can i reach speed of 100 km/h ?
Thank you in advance.
Technical info:
1850 RPM
Questions:
