Regen has high currents but the real amount you will be pumping back into the batteries is negligible at best. I think when you need to worry the most is heavy regen down very long stretches of hwy with a FULL pack. A very unlikely scenario. Unless you start at the very top with a very full pack then I'd say you will be fine with regen.
I don't know too many folks who actually ride the brake down any type of grade for any more than a sec or two anyway. An occasional press on the brake to help control speed even in a coasting situation is more likely the truth. If you ride your brakes you are not in control.
Don't worry about regen. Use it when you need.
Pete
Pete
