I posted some pictures and description in my build thread regarding the state of the brushes in my new-to-me FB1-4001A motor. The motor is now out of the engine bay, and I was able to remove the end cap and get a better look at things. I'd appreciate any input on diagnosing its bench test failure (didn't spin under 12V power), aka, determining if I should go ahead and replace the brushes or if there's something else wrong that I need to dig into first.
I've seen that brushes getting stuck in the holders is common from carbon build-up after sitting for a long time, but that doesn't explain why half of them are popped up like that, and several having chunks missing from them. Does that white residue around the brushes provide any hints as to what happened or why they're so stuck?
The brush I successfully removed measured within 0.1mm of the new spec length, so they can't have been run for long. I assume the 7-14-09 on the nameplate indicates a 2009 build date, which means it was pretty new when the half-finished conversion took place by the PO.
While blowing out dust and cobwebs, a couple small shards of what looks like foil/paper insulation fell out. I couldn't spot anything missing or torn, but sitting for that long, it wouldn't be a shocker if critters got in there.
