1 - 20 of 79 Posts
I've been watching the AEM VCU-200 for a while now, but I haven't found anyone to successfully run it besides AEM in their black mustang and when they redid the EV West van. But I am assuming that both of those took forever to work and I am not really interested in being their guinea pig.
Is anyone running this and how hard was it to setup?
I wonder how this would work with an OEM EV, would love to drop this in my Focus Electric when it comes time to do a battery swap....
I have one and I plan on using them with their Tesla drop-in board on a sport drive unit. However, they have delayed this so part far out that I will use an Openinverter LDU for the time being. I tried to contact them many times about eta and support but they have not been helpful at all. If you buy this thing you will be on your own.
I really appreciate your response. I am also worried about using my vehicle as thier testing platform. It looks like a great product, if it works as stated, but I am having such a hard time with the easy stuff, I can't imagine trying to troubleshoot something that might not even work out the box.
Hopefully more people will comment on their use of the VCU-200.
What else is out there that is in a comparable price range to. The vcu200 and ldu board (~$2500)? I'm waiting on that setup as you are/were, but I'm not quite ready for it yet so I don't have the time pressure. I was told by their sales dept they are beta testing the ldu board now with existing swap shops and are planning for it to go live later this year (so much for Q1 2021).
I find that getting knowledge of inverter board options is really scattered and poorly organized, so any info here on options would be a huge help.
Discussion Starter · #9 ·
I don't need the idu board, but I have now ordered the Thunderstruck VCU. Over the last 6 months I've emailed AEM probably 10 times, and I've gotten a response one time. I've emailed Thunderstruck 4 times and they usually respond to me the same day. Building an EV is hard enough without being a beta tester and little support.
I work for AEM so maybe I can answer any questions you have. I am not here officially but if it's info I can share I will.
Biggest question is "When", and how plug-and-play is it? I'm not looking to squeeze every last ounce of torque out of my Tesla LDU, I just want something that will let me hook-up and go relatively easily. :)
Thanks Mojave!
Thanks Mojave!
The VCU 200 is shipping now (this thread is titled VCU200) but I think you are really talking about the Tesla base LDU board right?
Do you know if "Rywire" is up and running with the VCU-200? Do you know of any customers that have paid, received, and are using the VCU-200 successfully in a complete EV?
Don't know about Rywire. I have not had anything to do with them or any project they are working on.
The vast majority of AEM EV customers are dealers developing either complete or partial kits and it's not our place to say what they are doing. Some are already out there and of those the biggest is Cascadia (Reinhart Motion/AM Racing) but they are most definitely not the DIY crowd and their customers projects seem to fly way under the radar until they release them as fully formed products. That's why we do videos on some of our vehicles because if we didn't then there would be no publicity at all. Vehicles like the Ford Cobra Jet 1400 were built and running in 2019 but didn't get announced till mid-2020 and only in the last 6 months has it been out and about for people to see in person. The lead time on these projects is huge.
With all that said, the DIY application for the VCU200 or VCU300 as a stand alone device is fairly limited. It is a comprehensive vehicle controller that manages everything in the vehicle, because of this, it is not a casually installed add-on component. It needs to be designed in to the system from the very start because it will control everything and if you don't have it controlling everything then you are better off not using it. It wants to have full control over your contactors, Inverter, OBC, DCDC, BMS, J1772, Pumps, Fans, AC Compressor... everything because it's all functionally interconnected. Casually installing the VCU isn't possible, it's all or nothing. But because it is spec'd out at the very start of a vehicle concept and it is a relatively new product, I suspect you wont see the drive kits of finished vehicles the currently shipping VCU200 modules are going into for a while yet. I cant change that.
I really appreciate these responses, thank you.
I think I can do everything but A/C, cause I'm using a PWM (not CAN) compressor, unless the VCU200 will drive that. Otherwise I am totally fine running everything with the VCU (in fact I was hoping to).
Correct, specifically the LDU. I think I have plans for everything else that's just the last component... (I think)
I am not working on that specific project so I don't have dates or anything like that but I can say that it seems to either be complete and may just be in the buttoning up phase. Last I saw they were validating very high speed regen so there cant be much left if anything.
As to plug & play, well, you definitely need to read my response above regarding the system design function of the VCU200 & 300. I think the Tesla board version will be a little simpler since the motor is defined but you still have the rest of the vehicle to consider and how it will relate to the VCU. Also, I would definitely say it is not plug and play since to me that means you literally plug in the supplied harnesses and while there is one for the Tesla drive, the VCU does not have a generic harness, you need to build on so no plug & play for the VCU. Also, note that the control algorithm for the LDU controller is 100% CAN based, there is no stand alone mode for the LDU. Also the throttle pedal wiring does not go to the LDU either, everything needs to come in over CAN. That puts all the torque control functions into the VCU's hands, the LDU will no longer do anything but the most basic safety de-rate functions, shifting that over watch responsibility to the VCU and adjustable by the user.
I did however get to drive our mule Mustang with the VCU-200 & base LDU about a month ago and it was an absolute riot. I took it home for the weekend and scared my friends with 0-90 runs and overall put about 150 miles on it.
You can definitely control the A/C with PWM and keep the VCU completely out of it. For the VCU to do it then it needs to be one of the CAN based compressor units. Without that the VCU cant use the A/C along with a chiller to cool the batteries.
1 - 20 of 79 Posts
