Creating a thread to document learning about and implementing the AEM ECU to drive a dual-LDU vehicle.
The VCU300 and the Tesla LDU replacement logic boards are relatively new on the market and so not much in the way of support for newbies. The manual assumes a fair bit of basic knowledge and equipment is available on-hand so I'd like to fill in some of the blanks here as best I can in case it is helpful to others wishing to do similarly.
Please don't reply to this thread unless you have experience with this equipment or something relevant to add
The ECU looks like a stock OEM Bosch unit, similar to a EDC17 CP44. The CPU plus the power and can bus pins match at least
The instructions don't detail the header particularly well, it is a Bosch 196P EMS which is available as a kit from AEM or separately elsewhere
These use two terminal types
Matrix 1.2 Series CB 1.5mm2
BTL2.8 1.5-2.5mm2
Bosch sell an expensive crimp tool, a generic open-barrel/Weatherpack crimper seems to work ok.
The smaller Matrix 1.2 terminals use a single depinning tool
The larger BTL 2.8 pins require a dual fork depinning tool https://bosch-connectors.com/bcp/b2...ance/BTL-2-8-Disassembling-Tool/p/1928498715/
The Tesla LDU replacement board is not yet officially supported for dual-motor installations, VCU300, or for the Sport LDU.
It appears to be the front-end of a Cascadia inverter, configured for the power stage of the LDU. Since the VCU300 supports dual Cascadia drives, it also supports dual LDUs, once I figure out how to change can addresses.
Micro is a TI TMS320F28374S which is about as good as it gets; they are used in aerospace applications. https://www.ti.com/lit/ds/symlink/tms320f28378s.pdf
RS232 programming link is interesting; a bit 1982 perhaps. Not sure how to update the firmware when it is installed in-situ if it is done via this header, that would require a full car disassembly as the inverter covers can't come off in place. Might need an extra cable making up. No instructions were included with the hardware.
Search Results - automotiveconnectors.com
Stockists of a wide range of electrical and wiring products for the Automotive and Motorsport industries. Connector housings, terminals and accessories.
www.automotiveconnectors.com
BTL2.8 1.5-2.5mm2
