Oops, I meant in this sentence:
(The other terminal of the field wiring was terminated
at the field's negative terminal.)
To be:
at the armature's negative terminal.
Sorry about that.
To be:
Sorry about that.
--- Michael Barkley <[email protected]> wrote:
> I tried a SEPEX controller with my aircraft
> generator,
> it would not run. The two small terminals were not
> the field wiring, only one terminal was. The other
> who knows. The other terminal of the field wiring
> was
> terminated at the field's negative terminal.
> Therefore, I put a 24vdc battery pack in that wiring
> loop. Then I used an ALLTRAX 7245 to power the
> armature of the motor. It's working great for me
> this
> way.
> When I tried to use the controller to operate the
> field and armature at the same time, I didn't have
> enough dead stop torque to overcome a pebble in the
> road.
> I've got some drawings on this on: www.texomaev.com
> within the link of "Mitsubishi Eclipse Conversion
> Project" They may clear up some confusion of how to
> use the aircraft generator with a modern controller.
M. Barkley
www.texomaev.com
http://www.austinev.org/evalbum/1135
