1 - 2 of 2 Posts
Hi. What I perceive after reading few websites that car alternator converts AC to pulsating DC using diodes. After that a mechanical relay type vibrating switch is used to stabilize DC output within battery voltage range. I can break my question as below,
What is the ac voltage of alternator before rectification.
Why don't we use DC-DC converter after diode rectification as voltage regulator OR why don't we use AC-DC converter, eliminating diode rectification, as voltage regulator.
We have gone through some of this learning lesson recently, you may want to look at the past few posts on our blog. lopified.blogspot.com
1 - 2 of 2 Posts
