Hi, any thoughts on the Idea. Im new to the forum and the concept of doing an EV conversion. Im a former audio technician and have electronic trade in Australia. The more I read into it, it seems like the output of a controller/inverter is basically the same as an audio amplifier, just bigger and 3 channels (3 phase) instead of 2 (stereo). I feel capable of building this section of the controller and heatsinks, and liquid cooling as I also have plumbing experience (mainly at home but can solder quite well and seal/join copper pipes. Im just not good with the logic/brain board with all the programming etc.
I am also thinking of a 3 motor design (2 rear axle and 1 front - Im converting an old series 3 Land Rover and thinking of having on road all wheel drive as well as 4 wheel regen braking as well as leaving its original gearbox and transfer case in for off road mechanical 4 wheel drive so having 3 motors and 3 controllers provides good backup in case one or even two fail when off road. Ideally having 3 of each means I would like to keep the design as cheap as possible. Im even considering building my own motors and repurposing old front loader washing machine drum/barrels as waterproofing (with motors inside waterproof drum casing, and air intake, for additional air cooling, from up high or snorkel, connected via existing door seal to where front loader door was) for off road. I will post separately about motors when I have more details.
My thoughts on the controllers are to amplify the output of something like this:
I would need to check reviews about whichever smaller controller I use to amplify and make sure this and the amplifier I build supports the maximum speed/frequency I want the motor run at based on speed and number of coils in circumference /3 etc. as well as its quality/reliability.
Anyone tried this idea before?
