It looks like you have a rather large footprint for your DC-DC converters, indicating that they may be 2 watts or greater. I think the actual power required may be much less, as I explained in a post a couple weeks ago:
I also ran a simulation which showed that it might be about 1 watt, depending on various parameters. Can anyone confirm or refute my findings, and determine an actual power requirement for the DC-DC? The IGBT-specific DC-DC supplies I found are 2W, and are reasonably enough priced not to be an issue, but I'd like to know what's really needed and how to determine the power requirement.I was wondering about the formula for determining the power needed to drive an IGBT gate:
P=Ug²/Rg*(ton+toff)*fPWM
For a 30V gate voltage swing, with 10 ohms gate resistance, 100 nSec ton and toff, and 20 kHz PWM, I get:
(900 / 10 ) * 0.2uSec * 0.02MHz = 0.36W
Is this correct? Otherwise the ton and toff might be better calculated as the TC of the gate resistor and gate capacitance, which typically about 6nF for a TC of 60 nSec, which is even less than my estimate above. And the current through the resistor would need to be integrated over the charge and discharge times, making power even less.
There will also be whatever power is consumed by the gate driver, and that may be greater than that in the gate resistor. The A3120 appears to have a power dissipation less than 300 mW. So I think a 1W DC-DC should be adequate for under 20 kHz. Its current capacity is not an issue because the current for the charge and discharge pulse is taken from the output filter capacitors which are many times larger than the gate capacitance.
