Does anyone have a DIY design for an automated battery cell tester?
As my other post points out I am looking to build a battery pack for a race car with a large volt and amp draw. It has gotten down to the fact that we need to test cells to confirm advertised specs or discover unknown specs.
Thinking something using an arduino to control the load and log the data. Then I can use a PC to analyze the data from those logs.
The data will then be used to build up the complete race pack.
Specs for the test rig:
0-15 Volt (most cells are 3.2 to 4.2 Volts)
Up to 1500 AMP
Up to 8000 Watts
Max Load tests will run up to 2 minutes.
Lower 1C tests will be run upto an hour.
Would like the cells and test equipment to be water cooled by aluminium plates.
I would like to log: Time, Cell volts, Output AMPs, Cell Temp, Water Inlet temp, Water exit temp (anything else people can think of)
May want monitor more than one cell in a parallel or serial configuration.
Here are a couple that I have been looking at to use as a starting point and maybe scale up.
https://www.instructables.com/id/Arduino-Programmable-Constant-Current-Power-Resist/
https://www.youtube.com/watch?v=acAuW0IVXKw
I know that West Mountain has a tester for up to 2000W.
http://www.westmountainradio.com/product_info.php?products_id=sys2000_watt
Also I know some DC electronic loads like from BK Precision and they can do battery tests also they get up to $10,000.
