my thoughts is that its kinda dumb....
From a mechanical point of view, your proposing to keep the clutch, which adds rotational weight (Flywheel, pressure plate, clutch disc, clutch arm, throwout bearing etc) for no purpose and creates a weak point (the clutch disc) that'll fail under the high instant torque output of the motor.
Do you want to change gears while driving? Why? The useable rpm range of an electric motor makes that virtually pointless and if you did want to change gears while moving, its pretty simple to match the rpm's, use the syncros and shift up or down gears. its something that you would program into your inverter/controller and have a little practice while driving.
Much of what you wrote is "kinda dumb"
A clutch disc has much lower rotational inertia than a direct coupled motor rotor. That means smoking your syncros in no time if you speedshift your electric motor, even with your skillful matching of RPM, even with current cut off, with no clutch. It's not "simple" at all because the rotor is so massive...you'll smoke the syncros. Ever notice how light clitch discs are, how their mass is minimalized as radius increases? Ever look at the friction surfaces on a synchro?
Changing gears multiplies torque. You want 0-60? Yeah, low gear. You want top speed? Yeah, motor geared for that 0-60 won't get you there.
Not to mention efficiency, since most 1:1 ratios on transmissions these days are extremely efficient...but your 0-60 is gunna suck if you keep it 1:1.
So, yes, there's a reason the Rimac and the Rimac-sourced Taycan has a two speed gearbox. There's also a reason why Tesla Roadster 1.0 moved away from one.
Half the fun is working the tradeoffs in any EV design, whether OEM or shadetree mechanic. There's nothing "dumb" about including or deleting a transmission. Or, wanting to rev the motor...then dumping the clutch for even crazier launch torque.
To the point of revving for the sound, who's to say whether he's got a playing card clipped on with a clothespin or not? You all assume silence, sound deadening, rubber isolators, etc.
