Hi Russ,
I'm converting my Ducati to an EV. I've removed all ICE parts & am currently looking for a battery pack for it. I have a motor & controller already but I'm thinking of possibly upgrading to a more powerful pair. Please send me specs on the batteries you have. Covid-19 put a hold on my Boxster conversion -- it's at my uncle's ranch & they're not allowing visitors. I'll be needing all EV powertrain parts for it later on.
I attached pics of my bike & car EV projects.
Thanks, James
Hey EVriderz, I've built a few electric dirt bikes, and for your size of a bike, I would recommend a larger motor than we use.
The ME1616 is the same motor used in a lot of Zero Motorcycles, and pairing it up to a Sevcon controller is probably the best combo. Here is the specs on that motor.
Specifications
- Power: 20 kW Continuous, 55 kW Peak
- 5 pole motor
- Maximum recommended rotor speed: 6000 RPM
- Voltage: 48 to 120 VDC input to the control
- Torque constant of 0.33 Nm per Amp
- Armature Inertia: 45 Kg Cm Squared
- Current: 250 Amps AC continuous
- Peak current: 550 Amps AC for 1 minute
- Weight: 48 pounds
- Peak Stall Torque: 134 Nm.
- Cooling: Water cooled (50% Glycol)
- Includes temperature sensor
This good power and lower weight. Here is a good Package, but you want to go to 120V if you can for more speed. The torque constant is good on this motor.
This kit only goes to 96V, and you want water cooling, but you can use the radiator on the bike, one of them if there are 2. Pumps are easy to get ( Prius Inverter pump)
<table> <tbody> <tr> <td colspan="3"><strong>Electric Motorsport turn-key electric motor drive systems are regarded as some of the most cost-effective, practical, and dependable solutions for electric propulsion on the market. Our pre-assembled, progra
www.electricmotorsport.com
Sevcon seems to be the best Controller, it is just expensive to program.
If you want to talk more about this, start another post, and or send me a personal message, and I can help.
