Are EV200 Contactor coil leads polarized
3240 Views 7 Replies 4 Participants Last post by  DC Braveheart
I have a Kilovac EV200HAANA contactor (well 2 actually). I know that the contacts are polarized to ensure that the magnetic blowouts work, but what about the coil leads?
The datasheet is silent on that (http://relays.tycoelectronics.com/datasheets/ev200.pdf). There is red lead and a black - I assume red goes to +12VDC and black to ground ... can anyone confirm or correct me?
Thanks
1 - 8 of 8 Posts
Nevermind - it's right there in front of my eyes ... on the side view it says "BLACK = - COIL, RED = + COIL".
Oh well ...hope this helps someone else :)
Yeah, normally the coil isn't polarized, but these contactors have an economizer with some circuitry inside, so they need to be hooked up Black to com and red to +12V.
Just a side note of caution on the economizer in these contactors.
We have had a couple of cases where there is need of a capacitor or isolator on the 12 volt+ circuit. It seems there is a pulsed signal feedback generated in the econimizer that can interfere with other devices.
If you are getting weird performance of an electronic device on the same buss try a DC to DC isolator or a capacitor. We found it by disconnecting each device on the 12 volt circuit until the problem stopped.
MOV's (metal oxide varistor) are often used also for suppressing coil transients.
Thanks - I'll be on the lookout for that. Exactly how did you hook up the capacitor (I assume in series on the +12V lead) and what size did you use?
Regards
Regards
Bravehart
The capacitor goes across the 12 volt+ and 12 volt- In parallel, put it as close to the contactor as you can. I think we used a 100 volt 33 uf cap but I can't be sure. Could one of the electronic savy people chime in here.
I got the capacitor out of one of those Radio Shack assortment bags,:eek: It was the biggest and highest rated in the bag.
The tractor it is installed in is buried under a foot of snow so I can't go look.:D
Bravehart
Thanks Jim - I'll see what happens once I've got everything put together and if anything is acting up try this.
Regards
1 - 8 of 8 Posts
