I have made an electric go-kart using a 2000W BLDC motor, 48V 45.5Ah Li-ion battery and 60A 48V rated controller.
The kart moves properly, but if the acceleration pedal is given a sudden jerk (which happens often), even if it is small; the circuit gets cut-off. The on-off switch has to be on-offed again to make the kart start.
However, this problem only occurs in loaded condition i.e. on the road. In static condition no such problem occurs. I have also connected a 50A rated fuse, which is yet to burn-off despite the motor having a 60A peak rating.
I think there might be a problem with the acceleration pedal that it is not rated for this 60A current, but am yet to verify it. What is an acceleration pedal made-up of, a potentiometer? How can I make one DIY style?
What could be the possible problems? Or any ideas or solutions that I can work on. Please reply asap, its urgent.
