Ok so you guys gave me some great feedback. http://www.diyelectriccar.com/forums/showthread.php?p=228616#post228616
What I need now is the procedure for adjusting the Zivan. How do you measure the outputs when adjusting the pots. I understand increasing the voltage while decreasing the current ( amperage?) to maintain 2.16Kwt, but what is the procedure? Do you turn on the charger first, crank down the current, than turn up the voltage while monitoring with an in-line voltmeter and ampmeter? A little help please. All I want to do is adjust up my 120 volt pack to 144 volt for now. lead acid.
