s it true that if you put batteries in the freezer you could use them again?!?!?! i want to try it but i think it will blow up or something.
Not exactly. Lowering the temperature can extend the life of the batteries. Essentially you slow down the self-discharge rate. But if the battery is dead, freezing it won't help.s it true that if you put batteries in the freezer you could use them again?!?!?! i want to try it but i think it will blow up or something.
