No for high C-rate usage all the cells in a given serial string must match, really should be the same factory run and state of health.
Not so strictly, strings compared across the parallel connection, but usually parallel is joined first.
The batteries is not a place to try to save money, unless it's a throwaway learning project.
Can (should?) be at least 20-30% of the overall cost, on a low end build, say under 25K USD
