Yes, you'll be limited by the lowest-capacity cell; however, "amp-hour" capacities don't add but energy does...1 - You'll be limited by the weakest cells in a series string.
You used to have 4 @ 100 = 400ah.
Now you'll have 6 @ 89 = 534ah.
If they are in series you only have 89Ah total.1 - You'll be limited by the weakest cells in a series string.
It's not 600, but it's better than 400. And more importantly, if you need the higher voltage, you have it.
Yeah.If they are in series you only have 89Ah total.
