Those batteries can be found in a Chrysler Pacific mini van hybrid. They are arranged with six in series for a 350vdc nominal voltage and about 45ahr. Each module is 16s for a 67.2vdc nominal voltage and made from LG Chem pouch cells wielded on opposite ends in a "Z" shape. They have one or two temperature sensors depending on the module. The module has two connectors for the BMS each that are 8s. The arrangement of pins for the BMS is even in one connector and odd in the other connector... for example one connector would have pouch 1,3,5,7,9,11,13,15 plus the temperature sensors and the other connector would have pouch 2,4,6,8,10,12,14,16. ...or something similar. I have seen three different pairs of plugs for the BMS connection. I have bought two batches from the "TechDirect" guy. the first I got for 17 cents a watt after shipping and the second (smaller) batch was about 23 cents a watt. I have a total of 24 modules for my solar system. I had to use a constant 75 watt soldering iron to get a non cold solder wield when adding wires to the pouches. The pouches wicked the heat faster than the smaller irons could make it. I wanted to use the original connectors but my batch came with some different connectors and my wiring harnesses did not fit all the batteries. so i had to make my own connections. Hope all this helps.
Regards,
YS
