1 - 17 of 17 Posts
I'm working on a 7-pack design (4 in back, 3 in front), and I need to come up with a way to mount and secure the Tesla packs. While I definitely want to be safe and secure in mounting, and leave room for cooling and BMS connects, I'm not nuts about spending (e.g.) $2900 for two battery boxes.
Does anyone know of any open-source DIY options for mounting and securing the Tesla 5.6kWh packs? Any suggestions for how to proceed?
I’ve had a heck of a time sourcing the boxes. A couple false starts. Some friend of a friend who works at an EV shop who would do a side job etc. I had already prototyped with styrofoam and then 3/4 inch plywood and then 1/8 plywood panel. Current I’m working on the Fiverr app. ( think Etsy for engenders / web designers) after a couple false starts there I found e
Ive had the same struggles. Had a few people flake on design/fab. I’ve modeled in styrofoam then 3/4 ply and then 1/8 ply panel. Currently I’m using the Fiverr app ( think Etsy for freelance design) afrer a couple false starts I found this guy electro_cad who for 40 bucks is creating a 3 d model in solid works that I will use to have 3/16 aluminum (5052) lazer cut. I will end up doing all the welding. Never done aluminum welding but have YouTube lol….
Other than the little flimsy plastic railings on the side of the packs, is there any other way to secure these? Like, is there a through-hole mounting point or something?
The Tesla Model S/X modules are designed to be mounted by the flanges on the edges, which are not flimsy. There is no other way to secure them properly, and the clear covers are not intended to be structural.
Thanks! This is actually super helpful info! When you say that the plastic envelope is not structural, I assume that means I should not just stack the packs on top of eachother, but instead actually provide railings for the flanges to rest on properly, correct?
When you say that the plastic envelope is not structural, I assume that means I should just stack the packs on top of eachother, but instead actually provide railings for the flanges to rest on properly, correct?
Correct - you "should not just stack the packs on top of each other, but instead actually provide railings for the flanges to rest on properly".
When I was thinking/designing my project I enjoyed seeing what other people did with Tesla modules. I got a few ideas of what I might do, and a few of what I shouldn't do.
Here's a couple of YouTube videos that chronicle builds using Tesla modules. They're both series and these are just samples.
I Removed My Engine, There's No Turning Back! - Electric Camper Build Ep 2 - YouTube
DRIVING our TESLA powered VW T3 Electric van (#EVWT 32) - YouTube
What I learned building my car; everything fits on paper.
1 - 17 of 17 Posts
