Yup.
Assuming those are lithium cells, that's not a "bit" low.
It probably drops below LVC when a load is placed on it, assuming a LVC of 2.8V when a load is placed on it.My 36v ebike cuts out as soon as I put any sort of load on it, if I take it super gentle it's barely rideable. It has a 10 cell pack and one cell is a bit lower voltage than the others, 3.1v compared to 3.9 for the rest. Would this be causing the BMS to throw a wobbly and cut out?
Troubleshoot the problem first. Stuff's too expensive and labor intensive to throw guesses at it.If it turns out to be the BMS that's crook, can you point me in the right direction for a replacement, I don't seem to have much luck getting a quality one.....
