As it's currently winter here in Europe I'm coming to think about battery heating again. I'd already picked some heating film with a total output of 240W.
But now I'm thnking: what if you just run a constant current through the battery? That should heat them from inside out. The voltage drop is pretty significant at low temperatures so even low currents should cause heating.
I'm thinking about an inductor and an IGBT in series that is being clocked at a low duty cycle. Or shifting charge in and out of a capacitor. Whatever it is it shouldn't cause too much heat by itself. So a simple resistor is not a option.
Has anyone ever tried that? Couldn't find anything on the forum
