TL
R:
Looking for good options to build out a ~96v (up to 115) pack to drive about 25Kw of output. (AKA 250A @ 96v)
I'm thinking of upping the voltage just a hair to keep amps a bit lower since I'm already at high DC voltages.
For safety, I think I want to build this to be able to break the system into 48v packs when not in use. I'm sure that'll make the bms super happy.
Target is 20-40Kwh of storage. I need to support 250A of sustained drive current.
I see three possible solutions here.
1) LFP/LifePO4 cells.
32cells*3.2v = 102.4v
102.4*100Ah = 10.24Kwh
So, if I use say, 2 to 4 100ah cells in parallel to deliver the amperage I need, this gets pretty approachable. I can add a cell or two to the series config to up the voltage and reduce my amp load just a bit - and allow for puling a cells out of service if I have a failure. Cost: Around 2-4k depending on config/seller/shipping/etc.
2) EV traction pack reconfigure. An interesting pack to me is the BMW i3 pack. It uses something like 48v modules that are easy to remove and reconfigure into a 96v pack. It would be harder to up the voltage if I wanted to. In addition, It looks like about $3k for a likely degraded 22kwh on the open market for these.
3) Custom 18650/26650 cell packs.
This is interesting as I could build custom packs into waterproof pelican style cases. It would be a crap ton of cell welding. After poking around a bit, I've found a similar cost per Kwh unless I absolutely score some epic recycling deals. Seems like similar pricing otherwise and just a ton more fabrication work for me.
Have I missed anything I should seriously consider?
