I'm new at this and looking at monitoring the battery voltage, amp, temp. through CAN BUS. The reason is that my system is 500v and I cannot locate a guage that is compatible. I'm gathering that all of these things can be communicated via CAN BUS. I have an Orion BMS.
If this is the case, I will try to find a gauge that replaces my stock fuel gauge.
So my questions are:
Am I correct that I can monitor the s.o.c. through the BMS accurately?
Does anyone have a source of gauges that work through CAN BUS?
Does anyone know a good resource for getting started on CAN BUS?
Thank you,
Mitch
Thank you,
Mitch
