Hello,
I’m a member of the Formula Student Electric Germany team at the technical university of Hamburg.
In August 2012 we want to race our car against other teams. Our concept is almost finished, except for the battery and charging.
Since your community has been of so much help for us before with finding suitable motors, I’d now like to ask for some advice on batterys. Could you have a look on my rough calculations below and correct me if necessary? I personally have only started to research on batterys last night...
We will use an EMRAX motor for each rear wheel and probably the BAMOCAR-D3 Controller from UniTek.
The Motors are designed for up to 300 Volts. We think that we should use the maximum allowable Voltage for the best performance, since higher voltage means less current and less warming-up at same power. So 300V would be the output voltage of the controller, so the battery voltage should be a little bit above that, is that right? If the max. current for the controller is 250A and the max. dissipation is 2600W, then the voltage drop over the controller will be approx. 10V, so would 310 Volts be the optimum Voltage? Does this calculation make sense?
We would like to use LiPo cells, so for 310 Volts we would need 84 cells in series, 3,7 volts each. We need approx. 8 kwh, so each cell or group of cells connected in parallel would need 100Wh or 27Ah. Considering that we may never draw more than 100kw from the batterys, at 310 Volts the peak current could be 100000/310=322 Amps. So we would need to discharge with up to 12 C.
In the Formula Student rules it says the following:
“Each accumulator must be monitored by a battery management system whenever
the tractive system is active or the accumulator is connected to a charger.
The BMS must continuously measure the cell voltage of every cell in order to keep
the cells inside the allowed minimum and maximum cell voltage bound stated in the
cell data sheet.
The BMS must continuously measure the temperatures of critical points of the
accumulator to keep the cells below the allowed maximum cell temperature bound
stated in the cell data sheet.
The temperature of at least 35% of the cells has to be monitored by the BMS, if the
used accumulator cells are not intrinsically safe, which has to be proven by
corresponding documentation in the ESF. The monitored cells have to be equally
distributed over the accumulator container(s).
The BMS must be capable of shutting down the tractive system, if critical values are
detected.
FSE recommends to monitor every cell voltage and every cell temperature.”
Could anyone recommend suitable cells? Should we try to avoid connecting any cells in parallel, not only in order to minimize the amount of voltage and temperature sensors, but also because it is a problem to “balance” them?
Is it common to charge a battery pack with the same circuit as you discharge it, or would it be practical, to separate the pack for charging into smaller units? We will probably have 2-4 smaller packs rather than one big one anyway and we want to charge them outside the car.
Lukas
cell data sheet.
detected.
Lukas
