1 - 1 of 1 Posts
Before Weight: weighed each wheel prior to taking things apart. Initial weight is 2800lbs with the rear weighing about 100 pounds more than the front and the left about 60 pounds more than the right (LF:681, RF:670, LR:752, RR:706)
Goal is to be similar in weight and distribution after the conversion. I'll be doing some weight and moment estimates as I remove parts no longer needed and start installing the electric parts. If things start going the wrong way, I might move where one or two of the batteries go. Initial estimate is that the weight should be very similar.
Land vehicle Vehicle Car Bmw Bmw z3
Tire Automotive tire Wheel Alloy wheel Rim
1 - 1 of 1 Posts
