Hi cat,I am just getting started and I'm looking for options for my battery and charging. My design runs at 500v-600v, so regardless of what battery technology I use, I will need a way to charge this very large number of cells in series.
Can anyone briefly explain how this is done? It is necessary to generate one very large charging voltage, or is it more common to charge each cell, or small parts of the battery separately with multiple isolated chargers?
What role does the BMS play in charging?
With questions like these, I recommend you stop and rethink your plan. High voltage like that will kill you in a heartbeat, or somebody else. For a beginner on a first BEV, start small. Like a cart or bike. 48 volts is relatively safe and nonlethal. Or if you insist on converting a car, keep it under 200 V. Everybody makes mistakes and draws a spark or two. You want to learn from those experiences, not die.
major
