Zeva can do it, you'd need multiple modules for your configuration. http://www.zeva.com.au/index.php?product=133
Using a different bms requires much more work and skills than using for example Tom de Bree's SimpBMS, you only need comm's wires and the tesla bms board on the modules are perfect.I've finally decided to use Tesla modules for my conversion. The plan is for a 50kwh battery pack, so this will need 10 Tesla modules in series (240V total).
Is there an off the shelf BMS like Orion that I can use for this arrangement. Or should I go for one of the open-source products that require more skill to configure? I'm a complete newbie to the ev world, but have a basic knowledge of electronics and a keen interest in cars and computers.
Fantastic! I'll take a look at Tom de Brees' SimpleBMS asap.Using a different bms requires much more work and skills than using for example Tom de Bree's SimpBMS, you only need comm's wires and the tesla bms board on the modules are perfect.I've finally decided to use Tesla modules for my conversion. The plan is for a 50kwh battery pack, so this will need 10 Tesla modules in series (240V total).
Zeva looks good, but it looks like I'd need more than 350 Zeva module V3's for the 4440 cells in the 10 Tesla modules I plan to use.Zeva can do it, you'd need multiple modules for your configuration. http://www.zeva.com.au/index.php?product=133
The actual cell count doesn't matter, since a group of cells connected in parallel are a single cell as far as the BMS is concerned. A 16-module Tesla Model S/X battery needs 96 BMS channels, so that would be eight of the Zeva modules (at 12 cell levels each, which would be two battery modules each); the proposed 10-module battery would need five Zeva modules. Right?Zeva looks good, but it looks like I'd need more than 350 Zeva module V3's for the 4440 cells in the 10 Tesla modules I plan to use.
That makes sense. Tesla modules are 74p6s I believe. 10 modules will be 60 parallel sets. Using one Zeva module per 12 cell levels means I'll need only 5 Zeva V3's as you calculated. That's a relief. How tricky is it to pull out Tesla's built in bms and install the Zeva?The actual cell count doesn't matter, since a group of cells connected in parallel are a single cell as far as the BMS is concerned. A 16-module Tesla Model S/X battery needs 96 BMS channels, so that would be eight of the Zeva modules (at 12 cell levels each, which would be two battery modules each); the proposed 10-module battery would need five Zeva modules. Right?Zeva looks good, but it looks like I'd need more than 350 Zeva module V3's for the 4440 cells in the 10 Tesla modules I plan to use.
Makes me wonder... maybe Tesla modules isn't what you actually want ?That makes sense. Tesla modules are 74p6s I believe. 10 modules will be 60 parallel sets. Using one Zeva module per 12 cell levels means I'll need only 5 Zeva V3's as you calculated. That's a relief. How tricky is it to pull out Tesla's built in bms and install the Zeva?
I've quite a bit about the lack of longevity in Leaf batteries. I think Nissan now have a buyback programme for owners whose batteries are giving up before reasonable guarantee period. I thought about Volt modules, but they have such an awkward shape. If I pull them apart, I then lose both the system for keeping them tightly compressed as well as the liquid cooling system. Do you know if anyone has any workarounds for these two issues?Makes me wonder... maybe Tesla modules isn't what you actually want ?That makes sense. Tesla modules are 74p6s I believe. 10 modules will be 60 parallel sets. Using one Zeva module per 12 cell levels means I'll need only 5 Zeva V3's as you calculated. That's a relief. How tricky is it to pull out Tesla's built in bms and install the Zeva?How about Leaf or Volt modules instead ?![]()
Thanks Cricketo,Leaf has longevity issues are due to lack of cooling. Seemed like it was an issue only in extreme hot weather found in a few states. If you know where your modules come from, may be less of an issue. What's also important, Leaf modules are the easiest to work with - even if some cell starts giving you trouble, you can easily swap out the module. Not so much with a cell in a Tesla pack.
Yeah, Volt modules may be quite tricky if you have space constraints.
If you decide to go with Tesla modules and use the ZEVA BMS, have a look at page 4 and 5 my build thread that has some photos of that combination. My modules did not come with the Tesla slave boards, so I had to start from scratch. If the modules did have the Tesla slave boards, I may have decided to go with a system that made use of the Tesla boards, but the ZEVA system also works well.That makes sense. Tesla modules are 74p6s I believe. 10 modules will be 60 parallel sets. Using one Zeva module per 12 cell levels means I'll need only 5 Zeva V3's as you calculated. That's a relief. How tricky is it to pull out Tesla's built in bms and install the Zeva?
I'm torn between using;If you decide to go with Tesla modules and use the ZEVA BMS, have a look at page 4 and 5 my build thread that has some photos of that combination. My modules did not come with the Tesla slave boards, so I had to start from scratch. If the modules did have the Tesla slave boards, I may have decided to go with a system that made use of the Tesla boards, but the ZEVA system also works well.That makes sense. Tesla modules are 74p6s I believe. 10 modules will be 60 parallel sets. Using one Zeva module per 12 cell levels means I'll need only 5 Zeva V3's as you calculated. That's a relief. How tricky is it to pull out Tesla's built in bms and install the Zeva?
