Hi all,
I have two high voltage fuses I'm installing in my pack today.
Where is the best location to locate the fuses? My pack is physically separated into two main packs, so I'm thinking about having one fuse in between each pack side. The alternative is to put one of the fuses before the anderson connector (to the contactors and then the controller), but that doesn't seem to make sense to me.
Can someone confirm if my configuration is correct, or suggest a better location for the fuses?
Attached is a Sketchup screen capture showing the packs -- the Anderson connector is the square in the top left, and the two fuses are in between the two lines running from the front to the rear pack.
Thanks!
corbin
Thanks!
corbin
