Hi
Any advise on how to best wire up this FLT drive motor, i currently have it wired so feed into outer coils through the com, and back out again through a coil, as per a series motor, but is this correct, or should i connect a coil wire and com to one side of the battery, and and the other pair to the opposite terminal, as unless it is easier to construct with the extra terminals outside, otherwise i would only expect 2 wires out as per my pump motor, or is it a SE motor, but the coil wire from where i can see, seem thick. All the best Dave
