G
Guest
·Our new project is home. It was purchased as a complete running and registered EV. We are going to be going through this build and fixing the little quirks it has and may have. We will be swapping out batteries too. Currently it is at 144 volts but they are 12 volt Marine floodies. Ouch. We will get some new photos and we will inform you of our findings and changes and any new photos and logs we may attain.
The vehicle is a 77 MG Midget. Called Black Midge. Lets see what we can do to make this one sweet little ride. It currently sports a Kelly KDH14850B Series Controller and a Warp 9". Literally still new. Original Build began in 08 and changed a little during that time. Quickcharge Select-A-Charge charger on board set for floodies. Quickcharge now has a lithium battery algorithm that can be installed for a nominal fee if you send in your charger if you already have one like we do. They will set it up to charge a specific voltage and cell setup if you have lithium Prismatic cells like TS, CALB or Hi-Power or GBS. It is not adjustable but I am sure I could get them to install a couple different settings if I wanted to play with it a bit. I will talk to them again.
Pete
http://www.diyelectriccar.com/garage/cars/296
We continue to work on the VW Bus (Big-E)
Pete
