1 - 6 of 6 Posts
  • At a given KV rating, will a motor with higher Watts have more torque?
  • At a given watts rating, will a motor with lower KV's have more torque?
  • Can we calculate KV from rpm and volts? Eg, 4900rpm/72V=68KV ?
Yes, assuming the voltage ratings are the same; more watts = more amps at same voltage, and more amps at same KV = more torque.
Yes. Until you hit max RPM of course. Lower KV = more torque per amp and lower max RPM.
Sorta - field weakening exists; if you can find a torque curve, the point at which the torque begins to decrease (often the point where they declare 'peak horsepower') is the RPM you could use for KV.
Just a note about Kv: it really doesn't apply to series-wound brushed DC motors, and is essentially never given as a specification for motors suitable for car-sized and larger EVs (even in motor types where it would be reasonably applicable).
1 - 6 of 6 Posts
