Blew pack fuses on ignition. Curtis 1238se controller and AC-50 motor help
1592 Views 11 Replies 7 Participants Last post by  Russco
Sort of a huge disappointment, but after wiring up my whole conversion verifying the wiring and turning the ignition I blew the pack fuses and my worry is that I fried the controller.
I wired up my system matching the attached EV West schematic, I've got the AC-50 motor with the 1238SE-7971 controller.
I've got 5 Tesla Modules wired in series, they're divided into three battery boxes, two boxes each with two modules wired in series with those two boxes each containing one 150 V 600 amp fuse on the negative lead coming out of the box. Then the final battery has its own 150 V 600 amp fuse on the negative line, which is the pack most negative lead.
When I turned the ignition for the first time I heard a big click. I thought this was the contactor, but discovered the controller didn't light up, or turn on. I discovered that the fuse between the negative most battery terminal and the shunt had blown. I wasn't sure if it was perhaps a bad fuse, or what, so I thought I could perhaps test to see if it was by bypassing that last fuse and try again without touching the throttle or anything. I did that, and ended up blowing the two other fuses apparently?
Definitely a bit unsettling, as I checked all my HV wiring against the schematic. I measured resistance of the main contactor after the event (with batteries disconnected) and it looks like the contactor is still open so I'd imagine that wasn't the issue? I also checked resistance across B+ and B- on the Curtis controller and there was no resistance, but I'm not sure there is supposed to be. I checked to make sure that my KSI was still functioning correctly and it seems to be.
Where/what would you start to diagnose next? My fear is that I not only fried three $100 fuses but also a $2k+ controller.
Product Schematic Font Rectangle Parallel
1 - 12 of 12 Posts
I'd bet there's an error in your wiring!
It could be one of your contactors is actually shorting the pack for example.
I would break it down int bits. Disconnect the power going into the controller, DCDC converter and Charger & replace the pack fuses with some much smaller ones (10A say). Then try turning on the ignition. If one or more fuses blow, you have an issue somewhere in the wiring.
If the fuses don't blow, connect one of the components you've disconnected & re-try. That will enable you to find roughly where the problem lies.
Make sure the polarity of the power going in to each component is correct - particularly the controller. If it's connected backwards, it will present a dead short. Reversing the polarity will probably bust it - but you never know!
i would make 2 schematics, one for the HV stuff and one for the LV stuff. That single diagram is too confusing.
i don't see a precharge contactor, so i bet that the fuses blew from the huge inrush to capacitors in the charger, inverter and DC Converter. A capacitor looks like a short at turn-on.
i don't see a contactor on the HV(-) side to isolate the pack when all power if off.
Using a voltmeter check to see if you have any HV leakage to chassis. Measure from HV(-) to chassis and also from HV(+) to chassis. Is the DCDC an isolated converter?
if KSI is working, then controller will run its diagnostics and blink out whatever problem may be, including blown MOSFETs.
FWIW the EV West schematic for the 1239 controller(revision1.7, 9/22) shows a dedicated precharge circuit, something lacking in the 1238 schematic:
You might try to put a precharge resistor across the HV terminals of your main contactor(with the main battery disconnected, of course!). Someone here could size it for you. If you wait for the controller capacitors to charge-up through this resistor after the main disconnect switch is turned on and before the main contactor is activated, the controller may still work.
Before you do this, it looks like the 1238 has an ignition switch/HV relay controlled tap to pin 1 of the controller. This may be a HV feed to an internal controller precharge system. You can test this, if you can do it safely and carefully, by measuring for HV between the lead to pin 1 on the controller and B-, with the ignition switch/HV relay cycled on and off. Do this initially with the batteries and other parts of the system connected EXCEPT for the main contactor. Again, only do this if you can do it safely and carefully.
It's interesting that Curtis would switch to an external precharge system(if this is the case) in a presumably later model controller, the 1239.
Indeed 1238 is supposed to precharge via KSI, from Curtis docs:
The KSI input provides power for all low power control circuits. This includes the microprocessors,
power supply outputs, power for the digital and PWM driver outputs, the power-capacitor
precharge (before main contactor closure). Battery voltage is sensed on the input for the VCL battery
discharge function.
It has a dedicated parameter to enable / disable precharge.
If you use AC induction/asynchronous motor, you can consider using our controller.
Font Auto part Brand Fashion accessory Rectangle
Where to buy ?
Where to buy ?
We will ship controllers from China. You can add my contact information.
That's great, but where are the prices / ordering information ?
Our controller is custom made, so the price is not fixed. You can add me on WhatsApp or Wechat or email for communication.
You should have placed a 100 watt regular old household light bulb in series with any battery lead. When the contactor closes, the light should go out. If the light stays on, something is wrong.
This way, you won't harm anything if something is wrong.
Old startup procedure for any new conversion.
1 - 12 of 12 Posts
