1 - 2 of 2 Posts
I know that this is not the right place for solar, but you have a huge knowledge with LFP batteries.
We would like to install 12V 200Ah Thunder Sky batteries for solar application, but have no idea if we should use in this case BMS or solar charge controller or both?
How will work inverter, which is designed for lead acid batteries?
Thank you for your advice.
both, charge controller / maximum powerpoint tracker to get most out of the sun, and bms to prevent damage from over or undercharge of the pack/cells, and a proper bms can also balance the pack too.
1 - 2 of 2 Posts
