So I built the bonn charger somewhat simplified. It has a fan, 7.5uf capacitor, the inductor from a mot and a rectifier rated for 35a . The inductor dosent have multiple taps as I was attempting to keep it simple. It puts out 115.2v at 30a pretty clean.
The questions whats the best option to crank the voltage up. I'm trying for 144v pack charging or 172v output max
I am trying to setup this charger to ultimately use J1772 connections.
I can connect to 220/240v source not sure how the charger would work.
I would think I would build 2 each taking a leg and then putting the. DC outputs back together. Issue off the top is I would have to completely rewind my inductor to actually lower the output drastically. Also wonder about charge inequality from the 2 legs.
I can sacrifice some amps and use a dc booster. But then I suppose I would have to split the J connector leg off.
If anyone has any ideas they would be greatly appreciated.
