Used but in great working condition. Pulled from a custom electric car.
I have 1 unit.
$2,800 each but will consider all offers.
Specs From the Manufacturer:
The PowerBox is an intelligent control and distribution unit for the electric grid in a modern racing car, which is seamlessly integrated into the Bosch Motorsport system architecture. It is capable to replace all conventional relays, fuses and circuit breakers, simplifies wiring harnesses and provides diagnostic capabilities. The integrated PBX-software guarantees an easy programming of complex functions by intuitive handling.
Technical Specifications
Mechanical Data
Size | 214 x 159 x 57.5 mm |
Weight | 830 g |
Temp. range (at internal sensors) | -20 to 85°C |
Electrical Data
Supply voltage range | 5 to 20 V |
Current consumption | <1 A |
Maximum recommended output current | 120 A continuously
Inputs
12 analog inputs (16 bit resolution) switchable pull-up resistors |
4 digital inputs switchable pull-up/pull-down resistors |
Outputs
4 high power channels up to 40 A (parallel up to 80 A) |
4 high power channels up to 25 A |
22 high power channels up to 15 A |
6 multi purpose outputs up to 15 A (low side, high side, push-pull, PWM; two output stages can be combined to form an H-bridge) |
1 sensor supply 5 V with individual ground pin |
