1 - 9 of 9 Posts
This charger is designed special for charge single cell of LiFePO4 battery like Thunder-Sky, Sky-Energy battery etc with 10Amps at CC stage, and charging voltage is 3.65V.
Features:
It is very smart charger with universal voltage input;
100V-240V AC input for worldwide power support.
Constant charging current is ideal for faster charging, saving more time.
Stabilized output with low ripple.
It can charge any 3.2V LiFePO4 battery pack with capacity>10000mAh.
The Charger will cut off automatically if battery is full (1/10C)
Safety protection:
Over Voltage protection
Over Current protection
Short Circuit protection
Indicate by LED:
Red LED--- in charging
Green LED--- idle or battery full
Wires:
Red cayman clip +, black cayman clip-
Specification:
Input: AC 100-240V 50-60Hz 2A
Inrush current: 115V/40A (max), 230V/80A (max.) at 25℃ at cold start.
Output Voltage: DC 3.65VDC
Charging current: 10.0A±1.0A please find in attachment
Charging Curve:
Charging Mode:
1. CC(constant current) at 10A
2.CV(constant voltage) at 3.65V (working range 3.60V to 3.7V)
Warning:
Charge 3.2V LiFePO4 battery pack only.
Don’t expose the product to rain or humidity to prevent from electric shock.
It is normal if the product gets slightly hot in using.
Keep the product out of the reach of children.
Don’t remove the cover to prevent from electric shock.
USD39.99 delivered (flat international air mail) If interested PM or email .
cool product, and a good price, except that wide a tolerance is more than I would want. If I was going to use it for top balancing I would want something like +/- .1v and repeatability to +/-.01v
Charging Mode:
this sounds like a great alternative to a variable bench power supply, which costs closer to $150 for this max amperage. Only issue for me is the accuracy of that max voltage. You indicate in above statement that it might be +/- .05v but then in edit note that it is +/- .5 volt.....
which is it?
Charging Mode:
which is it?
Hello Dan,
Sorry for misleading you. But charging voltage is 3.65V , and tolerance is 0.05V so charging voltage range is 3.6V to 3.7V.
Sorry for misleading you. But charging voltage is 3.65V , and tolerance is 0.5V so charging voltage range is 3.6V to 3.7V.
I suspect you are still off by 10x.
If the nominal CV=3.65, and tolerance is .5v, you would have results ranging from 3.15-4.15v... which I suspect is not the case.
please check with your technical support and verify the accuracy, repeatability and tolerance of the calibration in these units... and you might want to revise your post to reflect these values.
What we want to know is how close to 3.65v the units are set to a lab quality calibration for the voltage, and how close individual units repeat the same value they are set to every time.
Discussion Starter · #9 ·
Thanks Dan, Yes tolerance should be 0.05V. norminal voltage is 3.65V
1 - 9 of 9 Posts
