1 - 10 of 10 Posts
Brusa NLG513 air cooled 3.3kW charger, the gold standard of programmable chargers
Specifications NLG513
AC Input NLG513 air NLG513 water
Min. input voltage 100 100 V
Max. input voltage 264 264 V
Min. input frequency 48 48 Hz
Max. input frequency 62 62 Hz
Max. input currenteff 16 16 A
Max. input power (by input currenteff = 16A) 3’680 3’680 W
Powerfactor >0.99 >0.99 ---
DC Output NLG513 air NLG513 water
Max. charging power 3’300 3’300 W
Voltage range 200–520 200–520 V
Charging voltage accuracy %
Max. charging current 12.5 12.5 A
Charging current accuracy %
Max. charging current-ripple (100%, fr = 2fn (100/120Hz) 12.5 12.5 A
Efficiency (P = Pa1max) 93 93 %
Mechanical data and cooling system NLG513 air NLG513 water
Weight (without coolant) 6.3 6.2 kg
Pressure drop @ 5l/min, Tcoolan = 25°C --- 50 mbar
Ambient temperature range (storage) -40 to +85 -40 to +85 °C
Ambient temperature range (operation) -25 to +70 -25 to +70 °C
Coolant temperature range for full power -20 to +40 -20 to +60 °C
IP-protection IP54 IP65 ---
Safety-and protection features NLG513 air NLG513 water
Insulation testing (AC input/DC output) 2 2 kV
Mains input overvoltage protection 264 264 V
Insulation resistance (initial) min. 2
https://www.google.com/search?rlz=1...sa+nlg513,online_chips:brusa+nlg5&sa=X&ved=0a
Asking $500 plus shipping, includes all cables (new) and connectors
121026
Hello hbthink, I messaged you some time (1month) ago but did not get a reply. Can you please get in contact with me for the sale of the NLG513? Cheers.
1 - 10 of 10 Posts
