So why not just charge to 369 volts?
I have a couple of these on route so I've been looking through the manual and program to create a charge profile.Disconnected BMS completely and charger aborted at 379V. So something to do with charger or nlg 513 doesn't like Leaf Batteries after 75% fir some reason. Any clues?
pm me your email and I'll zip up the manual and chargestar and send it overI have a couple of these on route so I've been looking through the manual and program to create a charge profile.
The first thing to do is check the program. What are the stages set up like? Is there a stage set up with a timeout condition, or something related to delta V or delta A or temperature or ??
They are very capable chargers, but if not set up correctly could easily perform outside of your expectations.
Are you charging from 120 or 240v?
Thank you, I believe I have what I need, the old version of the manual describes how to set up the master/booster configuration. I'd like to have a look at the stock program first but I'll likely create my own first checking the temperature and allowing the pack to heat up above zero before starting the first charge stage.pm me your email and I'll zip up the manual and chargestar and send it over![]()
I read this either in the manual or on a website, but couldn't figure out what should be my setting.I find i have to have the absolute max voltage setting around 25% higher than my charge cutoff voltage. If needed, reduce your nominal voltage to allow the headroom![]()
I wouldn't like to say other than to repeat that I find I have to go about 25% over my desired charge cutoff voltage to get it to work without hitting that errorI read this either in the manual or on a website, but couldn't figure out what should be my setting.
Below is Leaf Pack details and I want the Cutoff Voltage of 389V. What would you suggest my Charger Profile be?
100% SoC 393.6
90% SoC 388.8
80% SoC 384
75% SoC 381.6
50% SoC 369.6
Nominal Volts 360
20% SoC 355.2
10% SoC 353.76
10% SoC 350.4
10% SoC 348.96
0% SoC 345.6
