1 - 8 of 8 Posts
Hi,
Prestolite motor MTC-4001 uses (8) brushes part #MGP-12*. "*" would be replaced with letter designation for the grade. I forget that but recall they are grade H100 by Morganite. The size is .997×.548×~1-3/8"long. Service replacement part number may be different. Forklift parts/repair places should have suitable brushes because size was used on so many forktrucks. eBay sometimes has them.
Unusual they would wear out from normal use. What's the application?
Regards,
major
Hi,
Regards,
major
Thanks for the info.
They’re not worn out, I just bought a NOS motor and several of the brushes were bonded to the commutator and the brush holders. When I removed them several pieces were pulled off, so I figured I would replace them all and somehow get the carbon off the commutator.
To remove carbon/graphite stuck to comm try a seating stone.
Brush Seater
Actually a shaping stone. Will help new brushes to seat faster. Seating requires running while passing current. Can do with no-load at 12V. Watch RPM. Stay below 6000. Around 3000 good for break-in period.
major
1 - 8 of 8 Posts
