32 cells is usually what people use for a 96V system, so watch out because a 96V charger will likely go above your safe cell voltage unless you have it programmed correctly.Thanks for the reply. Do you mean the Elcon pfc 1500? I will be running 30 cells.
I have a lot to learn yet about lithium. 96/3.2 = 30. So I figured 30 cells. I can buy 32 if that's the way it ought to be.32 cells is usually what people use for a 96V system, so watch out because a 96V charger will likely go above your safe cell voltage unless you have it programmed correctly.
Charge voltage of Elcon is probably 3.65V per cell by default. They can program it to your needs though. 30 * 3.65V = 109.5V. I believe Frodus wanted to recommend you lower charge voltage per cell by using 32 cells. Because charger only goes to 109.5V increasing cell count leaves charge voltage per cell lower. 109.5 / 32 = 3.42V.I have a lot to learn yet about lithium. 96/3.2 = 30. So I figured 30 cells. I can buy 32 if that's the way it ought to be.
Output power. 1500 is 1500W and 3000 is 3000W. Roughly. See http://www.elconchargers.com/products.htmlWhat is the difference between the 1500, 2500, 3500 chargers?
