So I'm most of the way done building an electric cart for my kids...and myself really. I used 2 500W 36V DC motors, one on each rear wheel, and some cheap ebay 500w controllers.
The controllers didn't have reverse or electric braking so I got 2 DPDT stomp switches and placed them where the brake would be (both pressed by the same pedal). The speed controllers output runs up to the switches and the NC function send the power to the motor for forward. The NO function flops it to Rev.
This worked fine but the switches are not rated for the current and burn up. So I'm thinking I'll hook the switches up to some relays that can handle the amps.
Now, my actual questions.
1. Is it okay to suddenly switch the direction of power or will this harm the controllers/ motors? I was surprised that when you press the switch, you get pretty good braking at speed and only have to apply (reverse) throttle at very low speed to stop completely.
2. Is there a much better/ simpler way to add e-brakes to a controller that doesn't have them.
Thanks!
Thanks!
