I am trying to figure out a cabin heating solution for my conversion and am having a bit of trouble finding a definitive path to take. In my situation there is no making any use of the original HVAC housing or related components. They are archaic and cannot house both heat and AC. The aftermarket HVAC systems available don't appear to be suitable for swapping the wet heater core with a PTC core for various reasons. This leaves me with creating a closed and isolated loop of heated coolant to make use of the wet core in the chosen aftermarket HVAC. What I am having trouble figuring out is:
1.) Is a Tesla battery heater sufficiently powerful enough to heat the coolant in a completely isolated loop to use for cabin heat? Ideally around 180 degrees fahrenheit?
2.) If the Tesla battery heater is not sufficient, what other high voltage coolant heaters are out there that would be?
Efficiency is not a top concern as the climate the truck will be operated in would only make occasional use of the cabin heater. It just has to be there as an option when needed. I found a coolant heater that Borg Warner makes but it does not appear to be able to be purchased by the public. Has anyone used a HV coolant heater to heat the cabin? What did you use and how well did it work?
