Why Peukert.Hello, I threw together a diy electric bike
Update: just did a real world test until it was basically empty. It reads 38.9v at high load up a hill(dangerously low?) the controller cuts the power from time to time at this point. It reads 50.3 with no load. Why the huge voltage drop?
It sounds like you have too small of a pack.
Lead is quite saggy, at high amp draws its capacity is greatly reduced if you draw enough amps to pull its voltage too low it wears out faster.
Better off to consider either another chemistry, a larger capacity pack or an AGM pack.
