1 - 4 of 4 Posts
A complete newbie question as I research a potential EV conversion.
Is a Camry hybrid battery pack a good candidate to power a forklift DC motor?
The pack I'm looking at seems to have 34 modules at 7.5V and 6.5Ah each for roughly 255V total. That's only 1.6kWh, right? Probably not enough for a 900kg vehicle project.
Are these packs easy for DIY newbie to work with when it comes to BMS, controller, and charging setup?
1.6kWh isn't going to drive you very far. If you've got a pile of these hybrid packs lying around then it may be possible to assemble something larger together - but it's probably an easier starting point to get a larger pack or modules from a proper EV if you're going down the salvage route.
Commonly used are Tesla modules - though these are very pricey. I'm personally looking at using almost an entire Nissan Leaf battery pack for my future conversion. Also look into the Chevy Volt (Vauxhall/Opel Ampera in Europe) as these batteries have been used a lot in DIY builds.
1 - 4 of 4 Posts
