Hello all,
About 3 years ago (ish. It's been a while) my father and I began converting a '95 Probe GT to electric. It went through some necessary changes (read: newer controller when we blew up the first one) and we've now had it to the point where it drives for most of the summer. It's got an auto, annoyingly, but having found all the threads on here detailing ways to keep pressure, that shouldn't be an issue (though I myself would have preferred a manual). Recently, I began finishing all the little bits, making power cables, doing the little bits of wiring, etc.
Most of the info is in the garage:
http://www.diyelectriccar.com/garage/cars/341
Anyway, we're running 48 groups of 3 cells each, HiPower LiFePo4s, with an Electromotus EMUS BMS and a TC Charger 3kW (previously these were apparently called "Elcon" and before that, "Chinoz"). The BMS is designed to take complete control of the charger via CAN, but this is where the problem happens:
The two units WILL. NOT. COMMUNICATE.
According to every wiring diagram I've found (including both the charger AND the BMS') and others that have similar setups, the CAN L and CAN H of each device simply need to be tied together to the respective pins (which is hard enough, since the charger's CAN module has NO markings as to which is which) with 1 (or 2) 120Ω resistors to kill echoes. Still both the charger and BMS say there's no comm. I have measured the voltages at the BMS with the charger on and off, and they do rise/drop, each by half a volt.
The only thing I could come up with was that the charger and BMS need to share a common ground. Grounding the charger's AC side to the frame did nothing. There is a ground pin in the 7-pin connector on the charger itself, but that connector is already attached to the CAN module TC Charger supplies, and there's no way to add a ground wire.
I do plan on getting ahold of TC/Elcon/Chinoz/whatever and asking them about this, but I was hoping someone here might have experience with CAN or this combo. This is the last thing preventing us from getting the car on the road, and we'd really like to do so before snow.
