My car needs work on the brakes so that might be a good place for me to start.
Yep that is where most everyone with a C-car starts. Definately get the brakes cleaned up and fixed first, there is a lot of info floating around on them. A good walkthrough on rebuilding the front brake is here.
http://www.neon-john.com/EV/Citi_Home.htm
The next important aspect will be to check the brushes on the motor & clean it up. (this is especially important on a c-car that had an "unknown problem" or unknown past) A pair of brushes and even the holder is cheap but stepping on the gas and wondering why you aren't moving until smoke pops out can be very expensive.
I appreciate all the comments. I already purchased the Curtis controller rated at 48 volts and 250 amps. It's model 1510-5201. It is used but looks good. I paid $110 plus $25.00 for shipping.
My commuta-car seems to still have the original contactors. I wasn't planning on even messing with them. I'll probably need to go check out that C-car group first.
It is a good idea to ask us experts pointed questions so we don't give baseless oppinions on requirements. There are several in the C-car group that run their car on a very similar controller with no regrets. It depends on what you expect and where you will be driving. If you can live with the performance it will work out to be an EXCELLENT value!
I would argue however, that your car is ALREADY wired and ready to go with the old contactors, assuming someone didn't pull wiring, clean up the contactors and use them for tests, your accelleration will be strong. And it will be a lot easier to start with if everything is there, it will make basic tests easier and it will help bridge the gap while you are trying to figure out how to get the controller to fit in there and wire up. A diagram is nice but actually running wire can be a small challenge at times.
Remember...
There are also many in the C-car group that have gone back to contactors because of the improved acceleration and RANGE. Believe it or not if you are carefull in how you drive and have
few stops contactors will run you further in the 2nd & 3rd speeds than a PWM controller at the same speeds because there is no voltage drop. But your speed choices are very limited. And your acceleration is 1/4, half or full throttle only which will eat up range in stop and go traffic, but if you won't be driving stop and go
Another use for your contactors is to bypass the controller when you depress the pedal fully, so long as you leave the wiring alone and don't increase its size you shouldn't have any major issues on flat ground running a turbo of sorts and you might find it comes in handy once and a while.
They can also be used for forward reverse control.
I am not sure yet but I'm thinking 8 Trojan t-105 6 volt batteries might be what I'd like to use in the car.
Dan
Many people go with T-105's, personally I would go with the T-125's because of the added range and because they are many times the same price or very similar depending on who you buy them from. If you are planning on going "long distances" (at least for a c-car) splurge for the T-145's.
One thing you will have to check whatever battery you go with are the dimensions of the battery box and the dimensions of the battery you want to use.
In some cases you can't use the new style trojans if your car has the smaller battery boxes or worse yet has the batteries under the seat
A way around the smaller battery box problem is to weld up your own boxes.
The key with any of these suggestions is
- Get the important and necessary items working first, take care of basics like fluids and lines
- Get your brakes and master cylinder working or rebuilt
- Verify the wiring and test the car to make sure the contactors and everything clicks on as it should
- After you verify the car works then buy the batteries you want and enable the controller.
Good Luck
Ryan
