1 - 4 of 4 Posts
I ordered and used this adapter plate, it has drill marks and extra holes along the bottom edge, when I mounted to my T5 Ford Transmission.
http://www.canev.com/adapters.php
It can be yours for $200 + shipping if you are on a budget and don't want to spend the $850+
low mileage, no warping, about 3k miles, on a low torque setup.
One ratted out hole, is not a mounting hole, doesn't affect mounting, it was simply for a manual clutch cable to pass through.
my pics:
https://www.dropbox.com/s/xvmcz14ahnhfoah/canev-adapter-front.jpg?dl=0
https://www.dropbox.com/s/oz0fcnuwvawpyu7/canev-adapter.jpg?dl=0
https://www.dropbox.com/s/gdo7k7erzdaiuqw/canev-bearing.jpg?dl=0
Josh
my pics:
Josh
Hey Josh I might want to buy this thing from you... What kinda Bell house did this bolt to?
Does it come with the fly wheel coupler too??
my pics:
Josh
Hey man I’m interested in this ...
Cool yes it couples to a Ford Small Block style. I had it hooked up to a T5 transmission which is pretty common in Mustangs etc.
It does have the coupler. It is a 6 bolt pattern (not 8) so double check which flywheel you have on your Ford.
send me a PM or email to josh at cool blue water dot org
Josh
1 - 4 of 4 Posts
